by christinnion Investigator
How do I see recent data usage on my phone?
I want to see itemised data usage but don’t know where to find it? I want to see what I’m using and when. My phone bill is increasing month by month but haven’t really changed the way I use my phone
Is there a way to see what apps is using my data each month?
Re: Is there a way to see what apps is using my data each month?
@christinnion: Which phone? There should be a list of apps' usage somewhere under Mobile Data.
I have seen a useage on my phone but that is total usage. I was wondering if ee had some way of showing what I used and when. I could see if watching Netflix on 4g used up 1Gig for example yesterday. I just want to pin down what I am doing which I should stop to conserve my data
Hi @christinnion,
Welcome to the EE Community.
We can't give you a breakdown of which apps or services are using data on your device.
As @XRaySpeX said, most phones will break this down for you.
Which phone are you using?
