by Chrissydav
How do I manage data between phones
I have 5gb between 2 numbers, I was told I can manage who has what amount online between the 2 devices but I can't see where I can do this????
by Brilliant Contributor
Re: How do I manage data between phones
This is not possible.
You can turn data off to a certain phone/sim but you can't set a limit to each device.
by Chrissydav
I have been told twice it is possible by EE but I need to do it online. Just can't see where.
Have you looked at EE shared plan help page here. It doesn't look like you can allocate out certain percentage of data just stop or start individuals.
It might be worth calling CS tomorrow and asking them again as to how this is done if you spoke to them before.
I used to have a shared data plan.
This was never an option for me but you could turn off data to a so certain device.
@Chrissydav  You can not set a allowance for each device it's a first come first served.
