by PDhillon
How do I find out my remaining minutes ?
by Ace Contributor
Re: How do I find out my remaining minutes ?
Hi @PDhillon If you log into MyEE you will see this information.
You can also download the MyEE app from the standard app stores for your phone.
Let us know if you need anything further.
by Ace Contributor
Hi @PDhillon
You cal also do this by text AL to 150 ,
by Ace Contributor
@tahirmian I was going to suggest that, but I tested it, and BALANCE, and got incorrect information, it says I've not used any data, byt MyEE shows I have.
by Ace Contributor
Hi @chistery To check remaining data http://add-on.ee.co.uk/status is the best.
Hi @PDhillon
Welcome to the community. 🙂
Did you manage to find the information that you were looking for?
