by Woodtown Investigator
How do I check what LTE bands are on my local mast?
7 REPLIES 7
Re: How do I check what LTE bands are on my local mast?
Hi there @Woodtown
You can check 4G, 3G and 2G in your area on our EE Coverage Checker.
If you enter your postcode this will give you the information for your area.
Thanks, Leanne.
Hi Leanne,
I'm not after the coverage I want to know which LTE _frequency bands_ are available on my local mast.
For example, channel 20 (800MHz) appears to have disappeared and I'm left with channel 3 (1800MHz) which isn't very good for a remote (we're quite a distance from the mast) connection.
Is it my LTE router (I've tried two with the same result) or is it EE?
Angus
I recommend speaking to our Tech Gurus. @Woodtown.
They'll be able to look into the infrastructure of your area and advise your further on what the problem could be.
Let us know how you get on.
How do I remove the 'SOLVED' flash, please?
I've done it for you, @Woodtown.
by Skilled Contributor
Skilled Contributor
To be fair, if your device is choosing B3-L1800 over B20-L800, it's probably by design or radio parameter - in other words, the network & phone is choosing it. L800 is a coverage layer of last resort and if any other 4G band is available, it will be preferred.
As for your other question, there are apps out there for Android phones that contribute to an online map doing exactly what you're looking for. But they're entirely independent of EE, third-party etc etc so a few minutes on Google should find them!
by Star Contributor
Star Contributor
Where are you? DM me a postcode and I'll take a look.
