by Boynton555
New Member
How do I add data to my ipad
I’m trying to add data to my iPad and it won’t let me without the number but obviously it’s a tablet and doesn’t have a number just the sim
Re: How do I add data to my ipad
@Boynton555   It does have a number as all sims have a number.   If you login to your EE account it will show the number for the sim that’s used in the iPad.
you can also click THIS on the iPad wifi WiFi turned off and your number will show at the top of the page.
Hi @Boynton555
Did you manage to add some data following @Chris_B's advice?
Recent solutions
