by GDHM
New Member
How could I use 30gb of data when I never even used 20gb with giffgaff?
Re: How could I use 30gb of data when I never even used 20gb with giffgaff?
Hi @GDHM,
If you check in your phone's settings, it should give you a breakdown of how much data each individual app is using.
If you need any help, just let us know which phone you are using.
by mister_johnn Contributor
Stream movies, download music, watch 4K clips, YouTube, Netflix, so on... You might need more than 30 GB 🙂
