by Daviest
How can I put extra data on my phone
I need to put extra data on my son phone for a week what is the best way of doing this
by Profile closed
Not applicable
Solution
Re: How can I put extra data on my phone
Hello @Daviest you can purchase extra data using this link from the phones data (not WiFi) connection under the purchase tab. :):
http://add-on.ee.co.uk
by Profile closed
Not applicable
Solution
