by mwalpole Established Contributor
How can I data roam in USA
I have a 4GEE Max plan and am disappointed to see even though it is supposed to be the top plan it does not allow me to purchase data roaming packs. Who thinks these things up??
Anyway, I am travelling to the States shortly and wonder if anyone can give me advice on how I can data roam.
I know worse case scenario I can use wifi or take a local sim but this is a lot of hassle and life will be so much easier if I can set something up through my EE account.
by Profile closed
Not applicable
Solution
Re: How can I data roam in USA
Hello @mwalpole are you abroad yet? You cannot purchase/activate a data roaming add on until you are in the selected country using this link:
http://add-on.ee.co.uk
More information on roaming charges and the add ons available for your selected country can be found using this link. :):
https://explore.ee.co.uk/roaming
by Profile closed
Not applicable
Solution
Thanks @Profile closed. It's a bit more pricey than the data pass but at least it allows me to roam.
by Profile closed
Not applicable
You are welcome @mwalpole come back to the community anytime if there is anything else you would like to know & enjoy your time away! 🙂
by Ace Contributor
Make sure your phoine is set up for roaming. text ROAMING to 150 now to see.
I'm off to NYC on Thur, and Vodafone gets my money when roaming.
