by Eamonn4492
How & where do I check 4G Download & upload speeds
See.  Above.  Topic!
by Ace Contributor
Solution
Re: How & where do I check 4G Download & upload speeds
@Eamonn4492
You check your speed though http://www.speedtest.net
You can download app from Apple or Android play Store.
Many Thanks
Try a speedtest here http://www.thinkbroadband.com/speedtest.html .
by Ace Contributor
Solution
@Eamonn4492
Many Thanks
