by merylchristine
New Member
Hi,I'm on a plan that allows me 20GB of data. How many GB of hotspot can I use?
Solution
Re: Hi,I'm on a plan that allows me 20GB of data. How many GB of hotspot can I u
@merylchristine   Your data to do with as you wish, so all of it if you want.  EE don’t set a limits like some networks do.
Solution
