by Holjon Investigator
Help with TP-Link MR400 and EE 4GEE sim.
im really struggling with connecting to the EE network with a TP-Link MR400 (Archer).  I can connect with my 4GEE box but I can’t with the TP-Link.
I have seen other people have this problem but couldn’t find a solution.
Thanks to anyone who can help!
jon
10 REPLIES 10
Re: Help with TP-Link MR400 and EE 4GEE sim.
What does the connection status say?
Status just says “Disconnected”
Hi @Holjon
Thanks for getting back to @XRaySpeX
When he's back on, I'm sure he will try and help you further.
Richard
That all? Are there no other settings regarding the connection? Like APN? Explore!
These are variations of the settings I have been trying.  Password - secure
I see you've tried IPv4. Try IPv6.
What are the other APN Types?
I have also tried with IPv6 and it didn’t connect either.
APN choices are Static and Dynamic.  I have tried dynamic but didn’t seem to help.
Is it possible the EE sim is locked to that device?
Jonathan
No, but it's possible TP-Link is locked to another network. Where did you get it?
It was from Amazon. It works with Virgin and Three with other sims I have tried. I have reset many times and updated to the latest firmware.
So, I have just bought a pay as you go sim from EE, popped it in and works straight away. I think it must be a problem at EE’s end with that particular SIM card / network.
These are the setting for the new sim and all works fine.
Recent solutions
