by Elaine19741 Investigator
Hello everyone again. Any ideas why my phone won't connect to the internet?
Hello does anyone have any idea why my phone won't connect to the internet. I have plenty of data as its updated on the 1st of every month. Tia
Re: Hello everyone again. Any ideas why my phone won't connect to the internet?
It could be one of a hundred reasons. You will need to provide a bit more info.
  • Does this happen in just one place?
  • Have you tried restarting your phone?
  • Is Data and sync active on your phone?
  • Have you checked your local network for issues on EE network checker?
Hi.
No it happens anywhere. The only thing i haven't done is check the sync. Could you advise me how to check that, sorry i am clueless.😁
@Elaine19741
What phone do you have? If Android pull down from the top of the screen and both data and sync will be shown as shortcuts. (data is normally two arrows, sync is two arrows forming a circle)
Also try downloading your Internet settings from  http://setup-ee.wdsglobal.com/internet
Hi @Elaine19741
Please try the link that @Northerner posted above.
Also, please check the network status checker to see if there are any maintenance works in your area.
