by teksysman
New Member
Having problems with certain sites not being reachable on 4GEE. Others are fine
I have recently (last few days) experienced certain sites (these apper to be predominantly .com) being unreachable.  The error is This site can't be reached.  ERR_SITE_UNREACHABLE.
All othere sites and email is perfect.  On the same device if I switch to any other provider the sites work prefectly.  This is using the same brouwser, same hardware and same configuration so only changing the Default Gatw=eway IP Address.
My Sim is in a 4G Router and the speeds we are getting are phenominal.
What could be the issue?
Euan
by Profile closed
Not applicable
Re: Having problems with certain sites not being reachable on 4GEE. Others are
Hello @teksysman do you still get the error message when you drop down to 3G using the EE SIM? Have you got the EE APN settings configured as follows:
Profile name: EE
APN: everywhere
username: eesecure
password: secure
