by petadata
Has anyone got 3G Dongle working with Tenda 3G150M
Have purchased EE 3G HUAWEI E3531 from EE with 2G allowance.
Set up and works in my laptop.
Trying to use with a router Tenda 3G150M
It says that it is compatible in the status of the router, with good signal strength, but does not want to connect.
The dongle light is solid blue, so it is connected.
The list of ISP's does not include EE, and there a number of entries for link connection.
Has anyone got this to work.
Thanks for your help.
Re: Has anyone got 3G Dongle working with Tenda 3G150M
Hi @petadata,
Have you spoken to the router manufacturer to see if they can help you set it up?
by petadata
Hi James,
Yes I have sent an email to Tenda in China. No doubt it will take a day or two to reply.
Regards
Andrew
Please let us know if they are able to help @petadata
