by Led
New Member
Had a text from 1024 telling me data has run out please confirm is this from EE
Hi had a text from 1024 telling me that my data has run out is this fromm EE or is it a scam please
by Brilliant Contributor
Re: Had a text from 1024 telling me data has run out please confirm is this from
One easy way to find out is to turn wifi off.
Try using data.
If you get a page asking you to buy more data then your data has run out.
If it works as normal then you still have data.
Hi there @Led
Welcome to the community.
We will send you a text message when your data has been used and let you know how you can purchase a data add-on 🙂
If you text BALANCE to 150, what reply do you get?
Leanne 🙂
