by MaciMimi Investigator
Got a text from 1024 that I’ve used up 80% of my data.
Got a text from 1024 that I’ve used up 80% of my 12G data? My average monthly usage is 2-3G.
Solution
Re: Got a text from 1024 that I’ve used up 80% of my data.
Hi @MaciMimi.
I recommend doing as @Northerner says and checking your My EE account or add-on status page to make sure that the text is definitely correct.
Let us know what it says. 🙂
8 REPLIES 8
Have you checked the EE app, or your online account to establish how much you have left?
Solution
Hi @MaciMimi.
Hi Chris,
Thanks for coming back to me. I’ve checked and it says the same although my average usage is around 2-3G even if I leave the country. I was at home almost the whole month and was using wifi. Something is definitly wrong.
Eva
Thanks for getting back to us, @MaciMimi.
What kind of phone do you use?
Have you started using any new apps or anything?
Have you noticed a deterioration in your WiFi connection at all?
Look forward to hearing from you.
Iphone 7 plus. Yes I had issues 3 times with my Virgin wifi but only for couple of hours.
I have a Nokia wifi camera a Nest app which I’m using to set the heating from my phone, but I’ve been using them for 2 months. Previous month usage was 2.5 G.
Thanks,
Eva
Thanks for confirming, @MacMimi.
Could you go into your settings and check how much data the new app has used please?:-
Tap Settings >>> Mobile Data >>> Scroll down.
The amount of data showing against each app is how much data the app has used since it was downloaded/the last time it was reset.
It may also be worth looking at your other apps on there to see if there are any anomalies.
Also, since you're having some problems with your WiFi, it may be worth turning off WiFi assist. It's right at the bottom of the page I pointed out above.
Thanks Chris. Just checked and it seems that my home cam took 8G out 12G due to issues with my wifi.
Thanks for your help!
Wowzers!
No worries, @MacMimi.
Glad I could help get to the bottom of it. 🙂
