by Nedkelly3
Gifting data
I'm due an upgrade. Looking at unlimited data sim. Currently I get 62gb a month, my daughter gets only 4gb,i give her 10 so. She doesn't go over.
Question is, if I he st unlimited, can I still gift data. Would ask EE but there no option on this app to live chat
by Brilliant Contributor
Solution
Re: Gifting data
Yes you can still gift data.
You can only gift the first 100GB
So if you use 50GB before gifting then you'll only have 50GB to gift.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.0)
Solution
Re: Gifting data
