by snappermex
GPRS 2G WAP Settings Gateway (IP) address for EE
I have a tracking device that uses GPRS 2G. I can find the APN name ok "everywhere" with username "eesecure" and password "secure" but I can't find the Gateway (IP) address for the APN "everywhere" on port 9201?
Does anyone know the Gateway IP address for port 9210 on EE?
by Ace Contributor
Re: GPRS 2G WAP Settings Gateway (IP) address for EE
HI,
@snappermex
You can find correct(EE APN settings here.)
I hope it will help you set it up.
Many Thanks
