Highlighted
New Member
Fb and Instagram wont connect to 4g . Samsung s9 everything else works
Fb and Instagram dont work on 4g since coming back from holiday (usa) switched of data roaming . But now back cant  connect everything else works . Went into EE shop told me to contact tech support ????
Highlighted
Solution
Re: Fb and Instagram wont connect to 4g . Samsung s9 everything else works
Could be your Switching Content Lock OFF or ON . It is switched on on new & upgraded contracts & seems to affect social sites. If just switching it OFF doesn't help, try switching it to STRICT, reboot your device and then switching it to OFF. That is seeming to do the trick.
Highlighted
Solution
