by Coolguy22468 Contributor
Family shared Plan question
I currently have a 24 month 4G EE mobile plan and I am looking at the £16.49 a month offer for my mum which comes with 20GB of data on a sim only contact for 12 months.
My question is though if I got the her that sim would EE allow us to combine our data into a shared data plan and if so would there be any extra charges?
Solution
Re: Family shared Plan question
@Coolguy22468   Sorry you can not combine tariffs.    It's one tariff that can be made in to a share tariff.   Your mum could share your allowance from your tariff  with you.    It will also cost £9 extra per month for this.
Solution
Ah so she would be able to use my data but not the other way around but it would cost her £9 per month?
EE Employee
Hi @Coolguy22468
Aslong as your account is a lead account and has more than 1gb data you can add sharers onto it.
Many thanks,
Lee
