Highlighted
by Investigator
Facebook
I have a P30PRO and cannot access  any Facebook apps over 4g.
Strangely I can receive notifications but when I try and view them .. nothing.
I have also noticed that when I try and log into them via their website an error message tells me I have to internet connection.
This appears to be a known problem. I've tried all suggestions bar a factory reset.
Where do I go for a fix?
Highlighted
Re: Facebook
Hi @AndyW1
Try logging into your MyEE app then - Settings - Content Lock - change this to off. Then restart your device.
It should now work.
Thanks,
