by ZoeB1
Facebook will not work on 4g only when I am connected to WiFi. iPhone user
Solution
Re: Facebook will not work on 4g only when I am connected to WiFi. iPhone user
Hi @ZoeB1.
Have you been able to make sure content lock is deactivated as @Northerner suggested?
If you've already done this, could you make sure Facebook is active in your mobile data settings under Settings, Mobile Data, then make sure all apps are toggled on.
Jon
Hi @ZoeB1
You need to log into your myEE app or online, then deactivate content lock
Solution
Hi @ZoeB1.
Jon
