by JaspreetBamra
Facebook Twitter and Instagram don't work on mobile data
Hi
I've researched this everywhere and tried to change APN settings as suggested.
Nothing is helping.
Facebook Twitter Instagram don't work
YouTube runs fine.
Re: Facebook Twitter and Instagram don't work on mobile data
Hi @JaspreetBamra
Try logging into your MyEE app then - Settings - Content Lock - change this to off. Then restart your device.
It should now work.
Thanks,
APNs don't come into it. Don't change it.
Could be your Switching Content Lock OFF or ON . It is switched on on new & upgraded contracts & seems to affect social sites. If just switching it OFF doesn't help, try switching it to STRICT, reboot your device and then switching it to OFF. That is seeming to do the trick.
Hi @JaspreetBamra
Welcome to the community. 🙂
The advice above should help fix this. Let us know if you still need some help.
Thanks.
Chris 🙂
by JaspreetBamra
Hi
I contacted someone very helpful from the Technical support in EE called Connor.
He reset the content lock even though it was already off and refreshed the network on my end. Fixed the issue.
Thanks to EE support.
Sent from my Samsung Galaxy smartphone.
Oh, that's great @JaspreetBamra.
I'm glad Connor was able to sort that out for you. 🙂
