by Sianverity
Facebook, Facebook messenger and Instagram won't load on 4G, how do I fix this?
I have a Huawei P90 pro and over the last four days realised that Instagram, Facebook and related apps won't load or refresh when using 4G. I've cleared the cache and restarted/turned my phone on and off again but nothing is working. Help!!
by Profile closed
Not applicable
Solution
Re: Facebook, Facebook messenger and Instagram won't load on 4G, how do I fix th
Hi, @Sianverity,
Other than what I already mentioned, you could try going into your account and switching content lock to STRICT and back OFF again! Or switching your device off and removing the sim card! and repeating the process, Those are all I know at this moment.
Thanks 🤗
BustaCrabb
by Profile closed
Not applicable
Hi, @Sianverity,
There has been numerous thread's on this issue you are having!
Can I suggest you try disabling content lock through the My EE app, please!
This should fix it!
Cheers 🤗
BustaCrabb
by Sianverity
Hi @Profile closed
Thanks for your reply!
My content lock was already turned off 😔🤔
Are there any other solutions?
Sian
by Profile closed
Not applicable
Solution
Hi, @Sianverity,
Thanks 🤗
BustaCrabb
by Sianverity
Turned my content lock to strict and back off again has worked!!!
Thank you so much!
Sian
by Profile closed
Not applicable
Hi, @Sianverity,
That's great news!👍
And thank to, for letting me know 🤗
Have a great day!
Cheers
BustaCrabb
Recent solutions
