by featherfoofer
Extra data from adding Broadband and Upgrade
Hi there, I received some extra data allowance once I'd added home broadband to my devices (before that I only had a mobile with EE). Now I would like to upgrade and get a slightly cheaper plan with less data. Will my extra data be added to this plan?
Re: Extra data from adding Broadband and Upgrade
Hi @featherfoofer
Your data is yours to own as long as you comply with the extra data promotion..
Good Morning @featherfoofer.
Welcome to the EE Community.
If you are eligible to upgrade you can move to a lower tariff, your home broadband data boost should still be applied to your new contract.
I hope this helps :),
Katie
