Highlighted
ERR_CONNECTION_CLOSED
I am unable to access websites when using my mobile dat . Anyone else having this issue?
Highlighted
Re: ERR_CONNECTION_CLOSED
Good Afternoon @Ge93
What phone are you using?
Does this happen within one specific area? if yes, please check the Network Status Checker for any reported problems.
Do you have data enabled within your phone settings?
Are you able to use apps that require data fine?
Katie 🙂
Highlighted
I'm using Samsung Galaxy S10, it happens in any location and I can use other apps. It's almost as if they are content locked despite having no content lock on.
Highlighted
Hi there @Ge93.
Thanks for getting back to me 🙂
Does it show your content lock is switched off within your My EE?
Are you able to perform a soft reset to see if this resolves the problem?
Katie
