by Steve34
EE eagle tab dropping off mobile signal and continuous restart
Hi can anyone help I've got an old EE eagle tab that has started dropping off mobile signal (just an x ) then it just restarts over and over again I've tried factory reset and it's still the same
Regards steve
Re: EE eagle tab dropping off mobile signal and continuous restart
@Steve34   Can you try a different SIM card in the device?
by Steve34
Hi Chris, yes I've put my phone sim card in and still does it, there's no recovery menu on here neither if I power off then hold power+volume up and down together the tab tries to update off sim card then fail and restart
