by joshhollands Investigator
EE Router issues
We have an EE Router which we run off a simcard.
Every day or so it will disconnect and only the power light will be lit and we have to restart it, how do we stop this so it is on 24/7 or restarts overnight not in the middle of the day?
The 'network' light went red earlier and now is green (usually blue) and is giving us 1mbs download instead of the usual 20mbs.
HELP!! Thanks
Josh
11 REPLIES 11
Re: EE Router issues
Hi @joshhollands
Welcome to the community. 🙂
Which model 4GEE WiFi device is it? You can see the range of devices on our device help page (using the 4GEE WiFi filter will help).
It looks like the 4GEE Wifi but in white
OK, thanks @joshhollands.
Is it the Osprey?
Yes it is this one
Brilliant, thanks @joshhollands. 🙂
Please try the hard reset instructions below:-
  1. While your router is turned on, press the reset button and hold it pressed for about 30 seconds.
  2. Still holding the reset button pressed, unplug the the router and hold the reset button for 30 more seconds.
  3. Still holding the reset button down, turn on the power to the router again and hold for 30 more seconds.
Please let me know if the issue re-occurs after this.
Hi, I'm back!
This fix worked for a couple of days but then again on Thursday it had turned itself off and again over the weekend?
Hi @joshhollands,
As the Osprey is designed for mobile use, it will automatically power off when it's been idle for a while to conserve battery life.
If you are looking for an 'always on' connection the 4GEE Router may be a better option for you.
I apologise, this is the router we have got. I've attached an image
Hi @joshhollands,
Great, you shouldn't be having this issue with that model.
Does the network status checker show any problems in your area?
No, this has been an ongoing issue since we've had it
Hi @joshhollands,
Thanks for checking. Smiley Happy
Please get in touch with customer services so our technical team can look at this in more detail for you.
Recent solutions
