by Brilliant Contributor
EE APN Settings: Where to find them
Many of you have been asking how to find and change your APN Settings.
Here I've listed how to find the APN Settings for EE on the various operating systems. I will also show you how to go about changing the APN settings in this post.
The majority of the Android platform the settings are the same and in the same place. It may differ slightly though.
  1. Go to Settings.
  2. Go to More.
  3. Go to Mobile Networks.
  4. Go to Access Point Names (APN).
  5. Go to Menu.
At this point you should insert a new APN for EE. Use the following.
APN: everywhere
Proxy: Not Required
Port: Not Required
Username: eesecure
Password: secure
Server: Not Required
MMSC: http://mms/
MMS proxy: 149.254.201.135
MMS port: 8080
MCC: 234
MNC: 30
Authentication type: Not Required or just use the default value shown.
Then Save the settings.
You will then need to restart your phone. Please test it has worked by trying to send an MMS.
  1. Go to Settings.
  2. Go to Network and Wireless.
  3. Go to Mobile+Sim.
  4. Go to Sim Settings.
  5. Choose + add an Internet APN.
Fill in the following fields.
Profile name: EE Internet
APN: everywhere
Username: eesecure
Password: secure
Tick the box next to 'Use this APN for LTE' and then tap Save.
  1. Choose + add an Internet APN
Profile name: EE MMS
APN: eezone
Username: eesecure
Password: secure
Proxy server: 149.254.201.135
Proxy Port: 8080
MMSC URL: http://mms/
Maximum MMS size: 1048576
The press Save and restart your phone.
  1. Go to Settings.
  2. Go to Network Connections.
  3. Go to Mobile Network.
  4. Choose APN.
  5. Select Mobile Plan Selector.
  6. Choose Contract or Prepay.
Access Point Name: everywhere
Username: eesecure
Password: secure
Press Save.
  1. Go to Settings.
  2. Go to Text Messages.
  3. Go to Advanced.
  4. Scroll past the SMS settings and find the APN Settings.
APN Settings:
APN: eezone
Username: eesecure
Password: secure
MMSC Settings:
Proxy URL: 149.253.201.135:8080
Then Save and restart your phone.
  1. Go to Menu.
  2. Go to Configuration.
  3. Go to Personal Settings.
  4. Choose Web.
  5. Press Account Name. Fill in EE Interent. Tap OK.
  6. Press Homepage. Fill in http://m.google.com. Tap OK.
  7. Press use pref.acc.pt then tap no.
  8. Press acc point sett > bearer settings.
  9. Choose pack. data acc. pt then type in everywhere and tap OK.
  10. Press username then type in eesecure and tap OK.
  11. Press password then type in secure and tap OK.
  12. Press the back button three times to go back to the network list.
  13. Press and hold the name EE Internet and then press activate.
  14. Press the back button.
  15. Choose def. config. sett and press personal config > default.
  16. Press the back button twice more and get back to the Home screen.
  17. Find and choose the menu option on the Home screen.
  18. Choose configuration.
  19. Choose personal settings.
  20. Choose options.
  21. Now choose add new.
  22. Choose multimedia msg. These settings will let you send picture messages.
  23. Choose account name, type in EE MMS, then choose OK.
  24. Choose server address, type in http://mms/ and choose OK.
  25. Choose use pref. acc. pt and Choose no.
  26. Choose acc point sett.
  27. Choose proxy, then Choose enable.
  28. Choose proxy address and type in 149.254.201.135, and choose OK.
  29. Choose proxy port, type in 8080 and choose OK.
  30. Choose bearer settings.
  31. Choose pack. data acc. pt, type in eezone and choose OK.
  32. Choose username, type in eesecure, and choose OK.
  33. Choose password, type in secure, and choose OK.
  34. Press the back button three times to return to the list of networks.
  35. Press and hold on the network name, EE MMS, then choose activate.
  36. Choose the back button.
  37. Choose def. config. sett. and then choose personal config.
  38. Choose default.
  39. Press the back button twice, which will take you back to the Home screen.
You are unable to update/change APN settings on an iPhone as these are locked out by the network. These are done by Carrier updates.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.0)
Re: EE APN Settings: Where to find them
You could just go here and download them to your phone.
by RML54 Established Contributor
This is a full and very interesting posting.
However,  it does not mention the IPv4 / IPv6 question. Some websites that claim to be IPv6 compliant don't work on EE 4g unless you set the phone to run IPv4 only (in the APN settings).   Examples of affceted websites are www.tolkiensociety.org and www.qustodio.com and the qustodio app.  There are many more.
I am no expert, but it seems to me that it would be useful if EE 4g would 'automatically drop down' from IPv6 to IPv4 if a website fails to work on IPv6.
If you search this community for 'qustodio' or 'tolkiensociety' you can find exampels of these discussions.
