by garadiff
EE 4G router connection to another wifi router
Hi, we have the EE mobile broadband with the 200GB plan as the wired internet in the area is very poor. The trouble is that the EE router is not powerful enough to get wifi around the entire house so we cant connect lights, nest and other smart devices. Hence the question, can I simply turn off the wifi and DHCP, then plug a new more powerful wifi router into the WAN port?
12 REPLIES 12
Re: EE 4G router connection to another wifi router
@garadiff  Why not just get wifi repeaters.  These can extend the range of the Wi-Fi signal
there are a 2 types available for your  situation from power line wifi repeaters to just wifi repeaters.
Ill go with the power line wifi repeaters as this will be the easiest to set up and your just going to be extending the original wifi range.
by EamonnC Contributor
how do I connect my Philips Hue lighting and other smart home devices that need an Ethernet connection
cheers
EE Employee
Hi @EamonnC
Have you tried and tested the second router option which has been mentioned by @garadiff
Many thanks,
Lee
@EamonnC Wifi repeaters have a  Ethernet port at the bottom of them
I would have thought most smart home devices run over WiFi.
Philips hue doesn’t connect wirelessly for a start, needs an Ethernet connection to router and so does my large photo printer.
I have a amplifi hd system so I don’t want to use Wi-fi extenders.
I thought the nighthawk supports IP Passthrough but am unable to get an answer to will it work. My question has been with product specialists without an answer for over 2 weeks now. I don’t know if EE have played around with the nighthawk as Telstra have done in Australia.
If the nighthawk does pass through or act as a bridge with the router disabled then I will buy one.
Cheers
Why don't you search the Netgear site & look at its spec, manuals & support articles? They'll know more than here.
I’ve done that. That is why I know it supports IP Passthrough. Why I don’t know is have EE tweaked the nighthawk. And that is why I am on this site
Sorry, the solution proposed will not work
Cheers
Sent from my iPad
EE Employee
Hi @EamonnC
I have chased this up again.
Many thanks,
Lee
Why should they?
Because nothing in this world is standard.
Sent from my iPad
