Highlighted
Does using social media apps like Facebook Instagram Snapchat use mobile data )
Highlighted
Re: Does using social media apps like Facebook Instagram Snapchat use mobile dat
@donovancarr: Yes, anything on the Internet uses mobile data unless you connect over WiFi. Only calls & texts are not data.
Highlighted
by Profile closed
Not applicable
Hi, @donovancarr,
If you mean which apps use up data quickly? Facebook/youtube/google-play music are the worst! 😊
Regards
mAh8v
Highlighted
by Expert Contributor
Expert Contributor
I think its a more nuanced question than that. Some providers zero rate the data for certain apps and services. So, for example, WhatsApp or Messenger use doesn't affect your mobile data allowance on Virgin. Netflix data isn't counted on Three etc.
Outside of the Apple music promotion, I don't think EE offers any inclusive use.
Highlighted
by Profile closed
Not applicable
Hi, @Techhead,
The 'apps' I mentioned do use a considerably amount of date, and are a huge drain on batteries too, but other 'apps' aren't so data hungry!
Regards
mAh8v
