by Biglorro78
New Member
Does unlimited data have limits?
I have connected my smart TV to my mobile hotspot, will this incur extra charges on to my unlimited data package?
TIA
Solution
Re: Does unlimited data have limits?
@Biglorro78 : Yes, the FUP on these plans is 1000 GB / month. EE would consider it commercial use if you went over 1000GB and would have the right to move you to a business plan .
by Ace Contributor
Hi, @Biglorro78  you can use your data as much you can if you have unlimited data.
Solution
