Highlighted
New Member
Does ee work in European countries
Can you make calls and use mobile data with ee in European countries
Highlighted
Solution
Re: Does ee work in European countries
Hi @gcullen
Yes, you can roam as at home in the EU. The only limit is on data which is limited to 15GB.
Just make sure to text ROAMING to 150 to ensure your service is activated.
For PAYG customers you don't need to worry your service is already activated.
Highlighted
Solution
Hi @gcullen
