Highlighted
by Contributor
Do all Mobile products get access to all bands?
Hi. EE offer Smart, Essential, Flex and PAYG plans to individuals. Do all these products get access to all the bands EE offer (assuming the phone supports them) or are certain bands limited to certain products. I'm thinking in particular of 800Mhz Band 20, is this available to all users or is it limited to the premium (more expensive) products. If so, which types of SIM/deals get access to Band 20? Cheers TB
Highlighted
Re: Do all Mobile products get access to all bands?
@Treebeard  if you wanna use band 20 then you’re going to need to be a contract customer.  That can be sim only.
Highlighted
by Contributor
@Chris_B Thank you for that. I suspected that something like that might be the case. Do you know if Is this info publicised anywhere? Cheers TB.
