by mhb1 Established Contributor
Do EE reduce transmitter power over weekends?
Do EE reduce transmitter power over weekends? I notice that although normally I get 3 signal bars (out of 4) over  weekends this reduces to 2 bars. Download speeds seem unaffected in spite of this, presumable due to reduced demand.
Solution
Re: Do EE reduce transmitter power over weekends?
9 REPLIES 9
Solution
Hello there @mhb1
You can check on any network problems in your area, on our network status checker>
If you select manage my places you can sign up for alerts for any service problems.
Thanks, Leanne.
by Brilliant Contributor
7
You say reduced demand but could it be because more people are at home over weekend so more people are connected to the mast?
Hi Leanne,
I am actually signed up to receive alerts and I do get them and currently all seems  well so I don't think this situation is the result of network faults as such.
Thanks anyway though.
Hi Brendon,
I did consider that but as the situation seems to start in the wee small hours of saturdays when presumably most people are  asleep. It really isn't a problem for me  as  download speeds seem unaffected, I'm just intrigued as to possible reasons
Ok, thanks Chris so now I can forget that possibility but am still intrigued as to the cause.
Hi there @mhb1
Thanks for coming back to me.
When this does happen, if you can report a problem on the network status checker.
We will be able to get this looked into.
Thanks, Leanne.
Hi Leanne,
Err, do I by any chance owe you a big thank you or is it just by coincidence that the signal strength has now returned to 3 bars?
Either way I am still grateful for your responses.
Hi @mhb1
I wish I had the ability 🙂
You're welcome, happy to help anytime.
Let me know how it goes.
