by TC442 Investigator
Disabled Customer
As I'm disabled and mostly housebound I've found I'm going through my 50GB allowance quite quickly is it possible to increase the allowance without paying an extortionate amount
13 REPLIES 13
Re: Disabled Customer
0.5
Regards
Tony
@TC442  You can increase the amount but it will come at a cost, give customer services a call and see what they can do for you.
Thanks, tried them but it goes up to £60 or £120 which is quite a jump up
Regards
Tony
Hi @TC442,
Welcome to the EE Community.
That's great advice from @Chris_B.
Please get in touch with customer services and they'll help you find a plan better suited to your needs.
Home Broadband package might be a suitable option.
Hi
Stuck with mobile as only option the cabinet I’m linked to is fibre enabled but we are too far away to benefit with no plans to upgrade
Regards
Tony
Hi @TC442,
Have you checked to see if you can get standard broadband if fibre isn't available?
Yes the signal best was 0.5
Regards
Tony
Hi @TC442,
Hopefully the broadband infrastructure in your area will be improved in the future.
In the meantime, it would be a case of upgrading your plan or reducing your data usage. There are a few things you can do to reduce your data usage, such as streaming video/music in lower quality and turning off automatic updates on your devices.
What does BT Broadband Availability Checker estimate for your landline phone number? Post just the whole table and the line above it, blanking out your phone number/address. If you don't have a landline, use the Address Checker, not the Postcode Checker.
May I see the BT Checker table? I may be able to advise further.
BT said our village would get fibre but they didn't say cabinet 10 dringhouses would be enabled but we are too far away to improve the speed of 0.5 which we've been getting.
0.5 was in my contract but we put up with it because fibre was coming, now it isn't mobile broadband is the only option that gives a decent signal but wanted to see if I can improve on 50GB as my disability leaves me housebound and extra data is expensive
Regards
Tony
Cab 10 has had Fibre since Oct 2012. If you would post that BT Checker, I'll explain further.
I know it’s fibre enabled but we are too far away to get it and there are no plans to enable us to get it
Regards
Tony
