by lawsonlaura1
Data usage
I ran out of data within 5 days which is unheard of. Purchased 1gb more which was used within 8 hours when half that time I was using WiFi and the other not really using. Figures don't tally with app usage data on phone. What is the issue?
by Ace Contributor
Re: Data usage
@lawsonlaura1
If you want to check which app using your more data for that go in phone settings > data usage >cellular data usage tap on that and you can find out app that using your more data.
Many Thanks
Re: Data usage
Re: Data usage
Good morning @lawsonlaura1
Thanks for coming to community for help and support 🙂
I know @tahirmian and @Chris_B have offered you help already on this.
You may need to have a chat with customer services about this if something doesn't quite look right on your usage.
Thank you
Richard
