by Kate1983 Investigator
Data usage going down when I have been on wifi all day?
I've had my contract for a month. Started on a 15gb plan. Although my previous contract wa only 8gb. Used 15gb in 2 weeks. Done a tariff changed on Thursday to a 40gb plan. This morning I had 14.8gb left. Shocking. There is no way I've used almost 25gb in 4 days? Then I've been on wifi all day and it's now gone down to 13.6gb any ideas why?
by Ace Contributor
Re: Data usage going down when I have been on wifi all day?
@Kate1983 Please can you share with us what is make and model of your phone?
And have you download any games or apps ?
Many Thanks
Hi iPhone 7 plus 128gb. The only things downloaded are the ones what I had on my iPhone 6.
Thx
by Ace Contributor
HI,
@Kate1983
Please click  [Here Check the data usage on your iPhone} which app using your more data.
then you can turn that off to save your data.
Many Thanks
Thanks I'll give it a go. Hopefully it works. Don't think I'm using my phone any different than I have for the past few years.
Morning @Kate1983.
Thanks for coming here.
Do you WiFi Assist turned on at all?
If you go into Settings > Mobile Data > WiFi Assist.
This will switch to your data if the WiFi has a poor connection.
Thanks 🙂
