by Immortality1 Investigator
Data usage disconnected
I am having issues that are related to one thing and that is the inability to connect to the data network.
With my old phone I would see an E, 3G, 4G or LTE next to my signal bars.
With my new phone moto g4 plus, I do not.
In mobile networks, the data is mentioned as disconnected.
Data type: 4g (recommended)
These are my APN settings;
APN: eezone
Proxy: not set
Port: not set
Username: eesecure
Password: ......
Server: not set
MMSC: http://MMS/
MMS proxy: 149.254.201.135
MMS PORT: 8080
MCC: 234
MNC: 30
Authenticity type: pap
APN protocol: ipv4
APN roaming protocol: ipv4
Bearer: unspecified
Mvno type: none
7 REPLIES 7
Re: Data usage disconnected
Have you deactivated mobile date by mistake in the quick settings?
No. Mobile data is on/active.
But but data from the sim is deactivated
Are you PAYG or monthly contract?
Sim only contract
by ukperson Established Contributor
does the 3G/h/4G icon show ? (make sure the Dot on the APN settings is selected on the EE APN, norm has a green dot on it)
can you make calls or send text from the sim
I have a blacked out H+ or 3G icon, ie. Inactive.
In the A,PN settings, the green dot is only on internet (everywhere)
The MMS eezone APN is below it, but not available to select.
Shall I create a new APN that can be selected.
Yes calls and text are no problem.
EE Employee
Good Morning @Immortality1
It sounds like you could need a Network Refresh from our end to push the settings through.
I'll send you a Private Message with a link to our Tech Chat Team.
They'll be able to help!
Let us know what happens.
Thanks - Karen. Smiley Happy
