by Ash321 Investigator
Data setting not right
On my old phone I had no problems seamlessly going from places with recognised Wi-Fi to places where my Mobile Data would take over..downloading images etc on Whatsapp messages etc was never an issue. I only had 10GB data before.
I now have 30GB and thought I will be more exploring when away from recognised WiFi. I thought I could stream movies in surgery waiting rooms etc..
Sadly, I can't even download one image without a delay and numerous messages of 'Download failed.'
Is this because I am in areas which have no Wi-Fi signal whatsoever?
I just don't understand. I haven't been able to enjoy my new phone yet because of these issues..
Thank you for any advice.
15 REPLIES 15
by Ace Contributor
Re: Data setting not right
Hi @Ash321
What is make and model of your phone please,
Samsung S9
by Ace Contributor
Hi @Ash321
http://setup-ee.wdsglobal.com/internet?step=manufacturerselection.vm&contractId=230&countryId=36&net...
Open this above link and send internet settings on your phone.
Then try again.
Thanks,
You can see when you're using WiFi by the radiating WiFi symbol at the top of the screen. You won't connect to WiFi while you're out unless you deliberately choose to connect to a WiFi hotspot there or have done so previously there.
Hi @Ash321
Welcome to the community.
Could you try changing your data content controls within your My EE account?
Log in and go to MenuSettings > Manage Device.
by Skilled Contributor
Skilled Contributor
Is smart network switch turned on?
I thought it was. How do I check that it is switched on? Samsung S9 doesn't have an obvious switch for this..whereas as far as I remember, the Samsung S7 had an obvious switch for this..
Maybe I'm just unfamiliar with the technical dedcription of the switch now.
Thank you. In My EE Account, I don't see a 'Manage Device' option in Settings..
Skilled Contributor
It may be under additional settings within your WiFi settings. Although it sounds like your mobile data may be completely switched off, have you checked that?
Try "Turn on WiFi auto".
I don't know how to specifically 'turn on Wi-Fi auto', I thought it was auto as it is..
It is on.
Good Afternoon @Ash321.
Please follow the steps below and let me know if this option is switched on:
Swipe down notification panel and tap on Settings icon > Tap and hold the Wi-Fi symbol > Tap on the three vertical dots (Menu) > Select Advanced > Here you will see the option for Turn on Wi-Fi automatically.
Speak soon, Katie 🙂
[Image]
Get Outlook for Android
Hi @Ash321.
The image you have sent has not successfully came through, please try again.
Katie 🙂
