by Dazza180
Data pack not renewing
Hi.
I topped my phone up on Monday as requested by EE but my data pack has not renewed.
Is there any reason for this?
7 REPLIES 7
Re: Data pack not renewing
Hi @Dazza180
Thanks for posting on the community.
What reply do you get of you text BALANCE to 150?
What data pack do you usually have?
Speak soon 🙂
by marcus941
Hello
I have the same problem. I bought a 5GB add on last night because I had run out of data. My new 500GB was expected this morning but it isn't there and it says next renewal 26th Apr but it hasn't given me the 26th Mar data. I can't text as this data is for my dongle not a phone.
Hi there @marcus941
Are you able to start the data if you visit Add-on.ee.co.uk?
Could you also try restarting the device?
Speak soon.
by marcus941
HI
I don't see any option to start the data from there sorry. The progress bar is as below but there should now be 500GB on it. You can see from the history I bought an extra 100GB a few days ago because I had run out so I've been waiting for the renewal urgently.
Data add-on3.1GB left of 5GB
History
Data add-on
Data used up 100GB
Start date 21/03/2020
Data allowance
Data used up 500GB
Start date 26/02/2020
Data allowance
Time ran out 500GB
Start date 26/01/2020
Hi @marcus941
Thanks for checking this for me.
Did you try the restart?
Also, do you have a My EE account?
by marcus941
Hi
I unplugges the dongle and plugged it back in but not sure if thsi will have done anything. It is working fine as it still has 3GB data from the top up. My EE account still shows only the 3GB data and next renewal 26th April so it's just completely missed out March
Thanks for trying @marcus941
In this case, we will need to get this looked into further for you.
If you can give us a call on 0800 079 8586, they will check this month's pack for you.
Let me know how you get on.
