by Cornopean Investigator
Data connection fault. How can this be fixed?conn
I have no email or internet access on my mobile. It was suggested this a date connection fault. How can this be fixed?
Solution
Re: Data connection fault. How can this be fixed?conn
@Cornopean : Can you make & receive calls & texts?
Have you checked the Network Status Checker there & logged the problem?
Solution
Recent solutions
