by sdicken2 Investigator
Data black spot, no wifi , how can I boost signal in static caravan.
Re: Data black spot, no wifi , how can I boost signal in static caravan.
You cannot unless you can tether to another carrier which can offer better coverage in your area.
Regrettably EE cannot guarantee a service in all locations.
Hello there @sdicken2.
I am sorry to hear you have this in the caravan.
I would keep an eye on the EE Coverage Checker.
As we are pushing our network to more places than ever before, bringing superfast 4G to even more people.
Thanks. Leanne.
Static Caravan body seems to be restricting the signal as outside it is better. If I place the phone in the window And use it as a hot spot it's also a work around if inconvenient as standing outside in our British weather is not ideal.
Can I purchase an EE recommended antenna to capture the external signal and relay it inside I have seen different examples of such a device on the net but not sure if they will work.
EE Employee
Good Morning @sdicken2
The only recommended signal boosts we do are the signal boxes, but you need fixed line broadband to use of these.
It may be worth looking at a Mobile Broadband option if this is something you use regularly.
Thanks - Karen. Smiley Happy
