by JosieLauren23
Data abroad
I am using my phone abroad on a EE Extra tariff and can only use 500mg of ny 2gb a month. Is there a way I can upgrade this to use all of it?
Re: Data abroad
EE Employee
Re: Data abroad
Welcome to the Community @JosieLauren23
The only way to increase your EU data allowance would be to change your plan.
Max Plans have different EU data allowances and do cost more than the standard plans.
If this is an option Customer Services will be able to avise what plans are available.
Thanks - Karen. Smiley Happy
by Ace Contributor
Re: Data abroad
Wait till next month and see what EE announce for existing customers roaming in the EU?
by Scholarly Contributor
Re: Data abroad
Hi Josie,
Starting next month, you'll be able to use all of your allowance due to EU rule changes so you might as well bare with it for now.
