by Farmer Investigator
Connecting a router to 4G router
We have a 4GEE mobile router and have just had electric heaters installed.They have a router which is connected by ethernet cable to the 4GEE router.So we can programme the heating by Heat App on our i-pad etc.Works fine indoors via wi-fi but will not connect from outside via 4G. Help please.
Solution
You need Port Forwarding
I don't think the device which controls the heaters is a router. it is a WiFi Controller which can be controlled from over the Net via a BB router & Wifi.
To do this from away from home your MBB router needs to open the port to the heaters Controller. This is done by the Port Forwarding function of a router but not many MBB routers, certainly not EE's, have this feature whereas most Home BB routers do.
Re: Connecting a router to 4G router
@Farmer  Does the app your using to control the heating say it can work over cellular data ?  or is it only a network connected devices that can connect to the heater ?   Does it allow remote access?
Yes it does allow cellular access.Worked fine with net gear router.The
installation company did port forwarding but cannot get it to work only on
wi fi.Not remotely.
Solution
by Prodigious Contributor
Re: You need Port Forwarding
True. I also suspect that the underlying problem will be the same that many CCTV, IoT products etc have on EE's network with all incoming connections being blocked. All to do with the public IP's allocated to end-users (even when using something like Dyn).
I don't think there's a way around this without getting a specific M2M tariff from EE business, or switching to Three who I think I've heard don't have the same restriction.
Also the EE network uses a Carrier-Grade NAT (CGNAT) system where the public IP is shared between many devices within EE's network. So your IP doesn't uniquely id your router.
