by NOLAN1984
Change phones NAT TYPE
If anyone can help. I work in the UK a lot so take my PS4 away with me, I play online using my phones "tethering and portable hotshot" mode on my Sony Xperia Z5. I'm sure all worked fine before my phones update but now when I connect my PS4 I'm getting a strict type 3 Nat type so making it harder to connect to some players / chat. Any way of changing the settings to open or at least moderate type 2? Thanks
15 REPLIES 15
Re: Change phones NAT TYPE
Have you tried this.
Thanks,
You won't be able to set DMZ or forward ports on your mobile. That's for real routers not mobile devices.
by NOLAN1984
Yeah that's all I've found guides like above but for routers. Is is some setting that EE can change?
No. EE mobile uses Carrier Grade Nat (CGNAT), which means that you don't get your own IP address but share it with other users. So you can't be uniquely id'ed on the Net.
by FrostbittenYeti
I was having this issue with my Nintendo Switch. Connecting to the internet ok but no online games.
I fixed it by adding a new access point.
This is in your phones network settings/data/advanced.
Named it Internet, set the same username and password as was used in the existing access point.
Username - eesecure
Password - secure
Didn't touch anything else and just saved.
Switched to my new access point and had NAT B instead of D.
Not sure why this worked.
Hi @FrostbittenYeti,
Thanks for visiting the EE Community to share this great tip. Smiley Happy
by adamlab Investigator
hi I'm having the same issue now on my Nintendo switch I'm on May type c and need it on nat type b for it to work any ideas ho e to fix this issue
changing nat type from C to B
hi group I've got a Nintendo switch and this EE mobile WiFi box. I am connected to the box but every time I do it keeps giving me nat type c and I need it on nat type b. I've asked a Facebook group and there telling me it's a nat type issue. I can see all my friends online etc but not able to play any online gaming. I have called up 150 and spoke with the ee Tec people but they don't have a clue how to fix this issue
Hi @adamlab,
Welcome to the EE Community.
Did @FrostbittenYeti's tip help?
no still can't get it to work
by FrostbittenYeti
I have noticed that when I created a new access point that there were a few extra things put under the option APN Type.
Try adding the below in your access point settings
APN Type - default,mms,supl,hipri,fota,ims,cbs
Hope that helps
still don't understand what you mean. I can see where you make a new access point but not sire what to put in all the boxs
by inkub69
Username - eesecure
Password - secure
It's working. But I noticed when I just setup new access point, you just need change one setting in old one. It's "APN protocol" originally is typed "IPv4/IPv6" you need to change this and leave only "IPv4" this change my NAT from type 3 to NAT type 2.
Now I'm just wondering is it possible to get NAT type 1? Even my router from EE is giving me NAT type 2 for my ps4, is there any solution to change for NAT type 1?
by inkub69
Username - eesecure
Password - secure
Nevermind about NAT type 1. I find answers, NAT type 2 is ok.
