by mawallace Contributor
Cat 9 - how far has it been rolled out?
When I was talking to an EE customer service he said that EE was rolling out Cat 9 across the country.
Can you please tell me how far this has reached - and what the coverage will be? Is there a map which will show us and can all plans benefit from it?
by Star Contributor
Star Contributor
Re: Cat 9 - how far has it been rolled out?
What does Cat 9 mean specifically to you?
4G of theoretical speeds^ up to ~412mbps is available in a significant number of cities and large towns.
The Pink '4G+' layer on EE's coverage map shows coverage where the theoretically attainable speed^ is 300mbps or above*.
^In optimal signal conditions and without concurrent utilisation.
*Broadly the '4G+' map layer is demonstrating Band 7 coverage, where Band 3 exists below. With 64QAM and 2x2 MIMO, 40MHz paired spectrum leads to a ~300mbps theoretical download speed. Further Band 7 spectrum, higher order MIMO and increased modulation level can increase this to near gigabit speeds.
Recent solutions
