by Cartwright3565
Cant connect to mobile data
Just got a new handset Samsung Galaxy A70 and for some reason it will connect fine to Wifi but when I turn Wifi off and select mobile data it won't connect.
Re: Cant connect to mobile data
Morning @Cartwright3565
Can you make calls and send texts?
Do you get an error message when you try and connect to data?
Speak soon 🙂
by Cartwright3565
All sorted now the phone started to connect to mobile data a few hours after I sent message thanks for replying
Get Outlook for Android
