by CousinT
Cant buy add on data in EU from EE phone with roaming enabled
Hi.
I've never had an issue doing so before, but I've not been able to access the data bundle roaming access site from Europe today.
I get the following message in my browser, using HTC One M8
add-on.ee.co.uk’s server DNS address could not be found.
DNS_PROBE_FINISHED_NXDOMAIN
Re: Cant buy add on data in EU from EE phone with roaming enabled
Try restarting your phone and trying again later as it could just be a temporary issue.
Thanks,
by just4clean
Hello, its very easy to make it work for android, ios and win systems https://ugetfix.com/ask/how-to-fix-error-code-dns_probe_finished_nxdomain-problem/
by GeeksAdvice
I had same issue, usually on business travels in different countries again and again, sometimes on IOS sometimes on Android, everything changed completely then i switch to Google's Dns 8.8.8.8 and 8.8.4.4 It depends on your gadget you can fix it easily by yourself DNS_PROBE_FINISHED_NXDOMAIN error
by bennetcole
New Member
It means that the DNS service is not working properly on either your side or the server's side. Changing DNS server to Google DNS or OpenDNS , or remove all cookies and cached files on your browser will help to resolve this issue immediately. Like any other error, there are several ways you can solve DNS_PROBE_FINISHED_NXDOMAIN problems by yourself.
Release or Renew Your IP Address
Change DNS server
Restart DNS Client service
Reset hosts file
Reset Chrome Flags
Reset Winsock program
