by terencewatts Established Contributor
Cannot connect to training platform
I have the new 4Gee modem but cannot connect to one of the online training platforms with it. Also cannot connect to my FTP client. Anybody have an answer?
22 REPLIES 22
by liam413 Established Contributor
Re: Cannot connect to training platform
Have you blocked the ftp port 21 through your firewall or modem?
No - I have another EE account and access everything well enough through that... I opened an extra account because I need more data and wanted it in two places in case something failed while I'm training online (It has happened)
The other accounnt is on a different router/modem though.
What is the URL of the online training platform?
More preceisley, I can connect to the platform but it doesn't connect into the classroom part of it - just shows the graphics and the message 'Trying to connect to whiteboard' but doesn't ever do so. the URL is http://www.wiziq.com - but it will connect at that point. It's a bit of a puzzle 😞
Is the whiteboard very graphical, with loads of links to its images? I remember a similar issue with such a page after logging in to something else.
Are you able to change the DNS in your MBB router or, at least, in the connecting device?
If so, you could try & get round this issue by switching the DNS to Manual with 1 of these public DNS:
Open DNS  :	208.67.222.222 & 208.67.220.220
Google DNS:	8.8.8.8 & 8.8.4.4
Norton DNS:	198.153.192.40 & 198.153.194.40
Well. I can have a look at that tomorrow - just about to start a class. It;s the 4GEE WiFi router, if that helps...
The whiteboad has only one graphic and on text file, so not loaded up.
EE Employee
Hi @terencewatts and welcome to the community.
Please do let us know how you get on after changing the DNS as mentioned by @XRaySpeX.
Many thanks,
Lee
It doesn't look as if I CAN change the DNS in the router... or at least I couldnt see how. I've only had a couple minutes to investigate though and have another class this evening.
It's the EE 4GEE WiFi router if that gives you a clue? I'm sure I'm just missing someting obvious!
Then change DNS in the device you are connecting from. Is it a PC?
It's a Mac - I'll give that a try in Netwok Settings tomorrow...
EE Employee
Hi @terencewatts
Please let us know how you get on with the advice given by @XRaySpeX
Many thanks,
Lee
That didn't work 😞 I couldn't connect to anything at all after that. So I've restored it to what was:
2a01:4c8:101c:4efb
6c8a:bde8:abf:fa5c
They don't look like DNS addresses of course, so now I'm even more confused!
I discovered this morning that Skype won't connect either, so it looks as if there may be quite a few limitations with the current setup.
EE Employee
Hi @terencewatts
Do you happen to use any VPN on your device.
Many thanks,
Lee
No, not to my knowledge anyway... my other EE account on the Assus router connects to everything with no problem. I can't imagine it's anything to do with the account though, so it has to be the router, wouldn't you think?
EE Employee
Hi @terencewatts
Do try and factory reset your router and let us know how you get on.
Many thanks,
Lee
Rebooted... then reset to factory standard. No different. I'm beginning to wonder if it's a faulty router.
Thanks for trying that, @terencewatts.
Please get in touch with our technical support team, they will be able to help you further.
Please let us know how you get on.
Chris 🙂
Apparently, they'll only communicate via the 'phone - but I have quite severe tinnitus (76 year old ears!) and phone conversations are difficult, as well as prone to me me not properly hearing some of what is said. Look as if I'll just have to put up with it or buy a different router 😞
I completely understand, @terencewatts.
If the 4G device is on a pay monthly contract, there is a chat team that can help.
This will appear at the top of the EE section on the get in touch page.
Fingers crossed they can help you get this sorted.
